Sheet metal cone ?
wayne_sauder
wayne_sauder Member, csevp Posts: 680 PRO
edited April 2017 in Community Support
Is there a way to convert a lofted cone to sheet metal? I know Onshape said they do not support rolled sheet metal at this point. I tried breaking it into many sides by sketching two equal sided polygons and lofting between them, and then step bending that, but that does not work either. Just wondering if there is a way to do something like this.
  • Tony_C_
    Tony_C_ Member Posts: 281 PRO
    Gotta try that.....I still do cones the old fashion way in 2D.....
  • wayne_sauder
    I understand both methods, For what i was trying to do using draft was the better method. It requires more calculations, because a lot of times i am given the top and bottom of a cone, and it would be easier to draw those and loft, although some math or a few simple sketches to find the angle is not hard either.  It would be nice to have a option for rolled sheet metal.
  • wayne_sauder
    Thanks Jake, that workflow works perfectly for what i want to do. Evidently my original problem was as you mentioned my polygons did not line up perfectly.
  • Jake_Rosenfeld
    Glad I could help Wayne.
