How to print a paper template from a sketch or face?
dmitry_olyenyov
dmitry_olyenyov Member Posts: 2 ✭
I've created a part with some big holes, now I want to print a paper template so I could cut it using power jigsaw, and a drill.. If I try to export sketch, it goes without dimensions and more importantly without centermarks. Is there any way to create real size dxf from sketch and with at least centermarks?
  • konstantin_shiriazdanov
    hi, create drawing of your part in 1:1 scale, place centermarks in drawing invironment using corresponding button, and export the drawing as .dxf
  • philip_thomas
    Hmm - i believe that there is much easier way! :)
    Simply RMB over the face and select Export as DWG/FXF
    You will get a borderless drawing at 1:1
    Philip Thomas - Onshape
  • dmitry_olyenyov
    Thank you! The trickiest part was to find where to specify 1:1 scale!
