How to merge 2 documents
AZΘRÆN
Member Posts: 22 ✭✭
I want to make 2 separate documents into 1 with the documents in separate tabs. How would I do this?
Right click the tabs at the bottom and select "move to document". Better to open the tab manager and do it from there then you can do multiple tabs at the same time. To move all the tabs from one document first create an empty part Studio (because a doc must have at least one tab)Senior Director, Technical Services, EMEA6
Cool thanks!0
