Insert DWG of DXF files in to assemblies?
david_gomez008
david_gomez008 Member Posts: 6 ✭
Hello,
Is it possible to import imported DWG or DXF files in to an assembly to use them as reference for a design intent?
  • david_gomez008
    Thanks I found out after posting this question.
    Now my problem is that the DXFs are too rich or complete to be used inside sketches...
    Thank you
  • brucebartlett
    brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
    Yes, I have had that problem too. Maybe we need an improvement request for better handling of large dxf's  in the sketcher if that is possible.
  • david_gomez008
    I've submitted one but if you submit another one it will increase the chances of getting things done faster.
    Thanks
