Issues with drawing on plane
isaac_oneil
isaac_oneil Member Posts: 15 ✭
edited April 2018 in Community Support
I attached my step by step attempt to draw a plane in my parts studio. I am having lots of issues with designing in context on both sides as it wont let me create a plane whose center point is a set distance away from the plane and whose edges are equal distance from part 1 and part 2's sides. I don't know if I designed each part correct or incorrectly to allow this to happen. Any and all insight to help is greatly appreciated.
  • owen_sparks
    Hi.  My security won't let me open the zip.  If you're happy to do so a link to the document would be more helpful.  People can then do the fix and save it so you can see what they did.
    Cheers, Owen S.
    HWM-Water Ltd
    Cannot open the mht file anyway (??) Copy and the paste the link to your public document.
  • isaac_oneil
    I have attached a link to the document and thanks to @NeilCooke I have attached a .gif of my issue.
     After doing much research I think its because I am selecting a fillet (I think that's what it is) and because of the way it joins two different planes, as a result I am unable to draw on it. I also have an issue creating a plane based off of it too.
    Link to document: https://cad.onshape.com/documents/8b6da23130a9dee535af0c96/w/f34a388fedf1c58e1269dcd5/e/1bd626987427970ee174e87b
    If you can't create a plane it's not planar
    edited July 2017
    There are however many ways to skin a cat. What are you trying to model?
  • isaac_oneil
    The end goal is to build a custom PC in a desk. I have contacted a company that is capable of making flexible displays, and I am trying to CAD out the design v1 for them so that they can say yes or yes but modify here or just no. The semi transparent screens would be over the part 1 and part 2 of the desk as well as part 3. The center area will be capable of tilting like a draft table and I will have monitor mounts coming off the backside. The table top will be height adjustable and the base will contain a small server rack to host well servers switches etc. That's the big picture, but first is learning how to CAD this out. I have also contacted a company who is capable of making a custom PC's, I just have to spring it on them that its more desk and less PC...
