Splines iPad pro
doug_meeuwsen
Member Posts: 2 ✭
would love to use this app. I need very little for what I do, just the ability to draw a spline and then move the spline points around a little bit. Amazing difficult apparently. Almost works with this app, but with pencil you can only grab a point about one in 5 tries. No rhyme or reason, just random functionality. Zooming in helps slightly, still impossible to use the app for this. No other app will do this either. Also, I can seem to find a ruler or grid in the app.... shouldn't be that hard to find I would think
To move a spline point, select it first with a single tap, then drag. Double tap in space to deselect. There is no grid or ruler. There are dimensions and a measure tool though.
Senior Director, Technical Services, EMEA0
