Inserting additional steps in the features list.
walter_randolph
Member Posts: 11 ✭
I was working on a model and realised when I had got quite a way into it that I needed to modify a loft about half way down. In order to do this, I needed a sketch prior to the loft in a new plane. Is there any way to insert new features in the list at an intermediate point. If there isn't, I might suggest that it would be a useful improvement.
@walter_randolph you can use the rollback bar to roll the featurelist back ahead of the loft, stopping regeneration at that point for you to insert the new sketch. Right click on the feature above the loft and select "Roll to here" to do this.
You could also create the sketch below the loft in the feature list and then drag it above it, but be sure that the new sketch does not reference any geometry from the loft before doing so.
Abe Feldman
UX/PD/Community Support6 -
Excellent. Many thanks. I knew about the roll back but thought it was only to step through the list. I didn't realise you could add features.
Abe Feldman
