How do I mate a hirth joint?
ihor_gernaga
Member Posts: 24 PRO
I haven't been able to mate a hirth joint correctly no matter what I choose to mate (point, plane or line). The one half has a rod that fits into a spindle and that mates fine which I mate first. Then I try to mate the hirth joint and it doesn't work. Search for hirth mate test on Public.
Thanks
Thanks
Mates in Onshape are a bit different than in other traditional CAD systems, see this video
https://www.youtube.com/watch?v=kK79nwi62Bg Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
ihor_gernaga said:
Please, share the link to the document instead wrote its name.Search for hirth mate test on Public.
Un saludo,
@ihor_gernaga - HELLO!
Welcome to Onshape!
Onshape mating is a little different. In general, if you find yourself trying to add a SECOND mate to any two parts, 9 times out of 10 you dont need it!
Check out this document for how to do it!
https://cad.onshape.com/documents/177be8e16c6cd305e8adc4bb/w/607d8ae70a9fcf4bf1640f94/e/f8929a19a8f1cd7c6e3b5865
Good luck!
Philip Thomas - Onshape1 -
Thank you Phillip. I still don't understand how one mate connector also aligns the teeth?0
Just edit one of the mate connectors so it is rotated until teeth are aligned. Then all you need to use is a fasten mate. You can also add mate conectors in part studios utilising sketches which can also be helpfulihor_gernaga said:Thank you Phillip. I still don't understand how one mate connector also aligns the teeth?1 -
Yes, what @brucebartlett said, explicit mate connectors declared in your partstudio are really helpful in cases like this.
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
Thank you, everyone. I appreciate your assistance.0
