Sketch plane is selected instead of face
Fox66
Fox66 Member Posts: 4 ✭
edited September 2017 in Community Support
The faces of a solid became unselectable after creating a sketch with only a point in it.  I realized that it is selecting the sketch "plane" instead of the face.  Is this expected behavior?  I tried this on multiple parts...  same behavior...
See 3 pictures.
Thank you for you help.
  • owen_sparks
    Hi @Fox66
    I believe you'll want to hide "Sketch 7".
    The dilemma of selecting 3D things on a 2D monitor...  Can't wait until we use VR and the cursor is a pointy stick than can pierce through things to select what's behind it.
    Owen S.
    HWM-Water Ltd
  • Jake_Rosenfeld
    In addition to Owen's suggestion, you can always use right-click > "Select other..." to pick a different selection than initial one we choose for you.
    https://cad.onshape.com/help/Content/select-other.htm
    NeilCooke Moderator, Onshape Employees Posts: 6,100 image
    Hovering over the sketch and pressing the "Y" key will hide it
