pdf Follow me
_Ðave_
Member, Developers Posts: 712 ✭✭✭✭
During a shared session with a colleague i switched to a pdf tab containing a drawing to explain a few issues when I quickly learned that the follow me mode only works in assembly and part studio tabs. Does anyone else have a need for sharing a pdf tab in the follow me mode and is this something that may be possible at some time in Onshape.
For external/non-CAD content like PDFs or images we're actually relying on the built-in support from your browser for viewing the files in an Onshape tab. As a result, your interaction with the file is entirely local to your machine/browser. When you're interacting with part studios and assemblies there is client/server interaction that can be shared with collaborators in follow mode.
I don't know if that will change but certainly if you've got use cases please share them with us and we can consider making changes.Kyle Smith / Principal Engineer / Onshape, Inc.5
This thing has two sides, if I would have customer on board and I would go to 'price calculation' tab - I would be happy that following stops.
On the other hand, I would like to have a collague following into sketch mode as well as all the tabs - but there are many tools like teamviewer available to achieve this.
//rami0 -
I don't know if that will change but certainly if you've got use cases please share them with us and we can consider making changes.Kyle Smith / Principal Engineer / Onshape, Inc.5 -
Hi @da_vicki , @3dcad how does the Follow Me mode works on Parts/assembly, I have shared a file with a coworker (Edit), he can immediately see my changes, but when I hear Follow me Mode I think that if I rotate/Move/zoom the part I'm working in, my co worker part will also move/rotate/zoom, etc. Not sure if I misunderstood the Follow Me Mode. Thanks.Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions0 -
When you and your co-worker are actively sharing a document you will see an icon in the top bar of the screen (rightside) with the initial of your coworker, your Coworker will see an icon with your initial. You need to double click this icon to view your coworkers screen or he can double click it to see your screen. Hope that helps.
1
