Can I set a specified distance between objects?
I am making a wall frame and I couldn't figure out how to position the nogs 800mm from each other. Please Help. Thanks in advance.
  • 3dcad
    You can do this in many ways as usual.
    If you are creating frame in single part studio, use dimension tool in sketch mode to set the distance (Onshape part studios support multipart design so you can model multiple parts from single sketch)
    Or if you are in assembly environment, then use (fastened) mate and add offset to set the distance.
    //rami
  • 3dcad
    //rami
