Can I export flat sketches as a drawing?
Catseyeguy
Member Posts: 4 ✭
Hello! I've only been using Onshape for a few months (off and on) so I only really know the basics. I am working on a project where I draw out plans, print them out, tape them to a sheet of foam, and cut them out. Unfortunately I cannot seem to find a on option to export sketches as flat, 2D drawings without first extruding them. Am I missing something?
Thanks!
Thanks!
Hi @Catseyeguy !
You should be able to right click on a sketch in the feature tree and export as DXF or DWG:
Is this not the format you need?Jake Rosenfeld - Modeling Team5
Hi @Catseyeguy !
Is this not the format you need?Jake Rosenfeld - Modeling Team5 -
Thank you so much! I usually print with Adobe Acrobat, but I'm pretty sure it supports DWG. Thanks again, Onshape is great.Jake_Rosenfeld said:Hi @Catseyeguy !
Is this not the format you need?1
