qEdgeAdjacent not working as I expect
pmd
Member, Developers Posts: 67 PRO
I must be missing something obvious but when I try and use qEdgeAdjacent(query, FACES) on the rim of an extrude-remove pocket it does not return any faces. I was expecting it to return the top face of the block and the side face of the pocket connected to the edge I selected.
https://cad.onshape.com/documents/42f66b52e9875b1e127d08fa/w/959ca6de0f8722ee1b8060ab/e/022e0d11157710c3636ca55f
Does anyone know why?
hi, make sure that you don't select sketch line as seed edge. hide your sketch and try again
2 -
Thanks - that was it!
