Routing (or similar) Feature?
dimitri_korchak
Member Posts: 2 ✭
I was wondering if there is a feature in Onshape similar to the 'routing' feature in SolidWorks.
The reason I'm asking is I'm trying to connect two parts in an assembly with a pipe, and I am wondering if there is a way to do in in the 'assembly' rather than creating multiple pipes as separate parts.
Thank you.
Thank you.
1
Onshape has multipart studios where you can create (or derive) those parts and easily sketch & model the pipe between.
//rami0
