Offset not working with DXF files
ideal_map
Member Posts: 3 ✭✭
Hi community
I have encountered some major problems designing a cookie cutter with stamp/ejector in onshape. I used a DXF file as sketch and wanted to offset the outline in the sketch to separate the cutter from the stamp/ejector. But this does not work. Any suggestions or workarounds?
Hi Simon, and welcome to the forums.
I would turn it into a solid and then boolean it with an offset from the ejector.
Something like this:-
Link to file:-
https://cad.onshape.com/documents/5d64f4c54cf2e48f9bc55ac3/w/e6243cb0a5c6802dc1ad2e59/e/f15582506a80b1adda7964ba
Hope that helps,
OwS.
HWM-Water Ltd0
