Offset not working with DXF files
ideal_map
ideal_map Member Posts: 3 ✭✭
Hi community
I have encountered some major problems designing a cookie cutter with stamp/ejector in onshape. I used a DXF file as sketch and wanted to offset the outline in the sketch to separate the cutter from the stamp/ejector. But this does not work. Any suggestions or workarounds?
