Data Management Certificate
patrick_anthony
Member Posts: 13 ✭✭
I have cimpleted all elements of the Data Management Tutorials, but my Certificate has not appeared in my Dashboard. I'd like to record & print it out like the other one that I obtained this Month. Thx
Patrick,
Thanks for reporting this, if you accidently skipped the survey at the end of the pathway, the certificate will not be issued. I was able to override this and you should have received your certificate now.
Thanks!5
Patrick,
Thanks!5 -
Thank you. I actually filled in the Survey a second time, when I discovered the certificate missing.0
I see the Certificate now. That treat is a great incentative to hang in with the tutorials. Thx. I look forward to more.0
hi,
I have complete the course and the survey as well, but the certificate doesn´t appear.0
