History Tree Names
in General
Currently HTN (History Tree Names) are in the following format
Extrude 1
Extrude 2
Revolve 1
Revolve 2
Chamfer 1
Chamfer 2
Fillet 1
Fillet 2
etc...
and this actually tell us only the type of the operation , yes we can rename them but this is time consuming
The suggestion is to have Names like:
Extrude 25mm
Revolve 30°
Chamfer 5mm
Fillet 8mm
Thicken 2mm
Draft 3°
Rib 2.5mm
Shell 2mm
Hole M10mm
Boolean Union (Subtract or Intersect)
Move 45mm (instead of Transform 1)
Copy 45mm (instead of Transform 2)
Modify fillet 8mm to 3mm
Move face 6mm
Offset surface 7mm
Plane offset 20mm
Helix 4 revolutions
etc.
Some of them will be repleted like
Fillet 5mm
Fillet 5mm
but this is better then Fillet 1, Fillet 2
Extrude 1
Extrude 2
Revolve 1
Revolve 2
Chamfer 1
Chamfer 2
Fillet 1
Fillet 2
etc...
Extrude 25mm
Revolve 30°
Chamfer 5mm
Fillet 8mm
Thicken 2mm
Draft 3°
Rib 2.5mm
Shell 2mm
Hole M10mm
Move face 6mm
Offset surface 7mm
Plane offset 20mm
Helix 4 revolutions
etc.
Fillet 5mm
Fillet 5mm
IR for AS/NZS 1100
I would like to do it. Could you please tell me how? Where is this place for enhancement request?
thanks
thanks Tony
