Offset face?
onshaper
Member, Mentor Posts: 99 ✭✭✭
Hey all,
How can I do an offset face in Onshape?
The idea is I built this part for 3d print, now I'd like to go to all slip fit surfaces and offset them by about 0.3mm to account for 3d printer squeeeeeze out.
Not sure what your part looks like but my first thought would be a Move face using the Offset (select offset from the drop down) .
Boolean offset using the mating parts as the tools also works well depending on how you've structured the part studio.
6
6 -
This is an example of the Boolean Subtract with offset to get .05 clearance. Hope this helps.
