Removing a complex solid geometry from another
joao_frangolho
Member Posts: 2 ✭
I work in the Checking Fixture (CF) industry and I use PTC Creo Parametric 3.0/4.0, and I have the need to subtract the part we are going to control, from a block
(Same thing happens with mould industry, or Progressive Die industry, remove a part from a block to have the negative and the positive sculped figure.)
Is there any command to subtract a complex solid from an extruded rectangle (for example)?
I hope there is a way you could help me
@joao_frangolho
The boolean subtract feature is probably what you are looking for. Here are is a post which explains how you can use it : https://www.onshape.com/cad-blog/tech-tip-booleans-in-onshape.
1
@joao_frangolho
1 -
@Paul_J_Premakumar,
Thank you very much, I also had to do some "cutting and sewing" work but i managed to get what I wanted0
