Edit Sheet Metal in Flattened State
mike_hölscher
Member Posts: 110 ✭✭✭✭
Hey,
Is it true that it is currently impossible to edit a Sheet Metal Model in its flattened state?
Or create a flattened state first and then bend this flat sheet?
We have an intern that needs to add specific geometry on a bend to create a special kind of leaf spring. This geometry needs to be added in a flattened state.
Thanks,
Mike
Thanks,
Mike
2
Yes it is true you can not do this with sheet metal as described. You may be able to get it to work with the sketch wrapper FS or some other workaround but ultimately we need to be able to sketch and add cut features to the flat view and have it auto update the bent part.
This Improvement request goes some of the way. https://forum.onshape.com/discussion/6414/sketch-bend-line#latest
7
7 -
@mike_hölscher,
Coincidental, yesterday I needed the same enhancement.
Therefor I posted the improvement request https://forum.onshape.com/discussion/8489/adding-a-hole-across-a-joint-before-bending-so-unbend-and-bend-back#latest.
1 -
I’m with Mike on this one. We also need this. In our case particularly for booleans. I’ll vote up that request.
Hendrik1
