How can I flatten a cone?
jiří_dostál
Member Posts: 2 ✭
Hello,
https://cad.onshape.com/documents/95a117275ce3cf54356153ea/w/cd81ce192f2fdc838ec27a3d/e/719f557e5e5f37962082f417
I'm a newbie trying to get a flattened version of this section of a cone. I've tried using sheet metal model, but it doesn't work with cones. Can someone point me towards a solution to this please?
To make it clear, i need 2d envelope from this 3d model.
@jeremy_lee540 the doc by link contains the original source of Sketch Wrapper feature which was used to flatten the cone.if the cone is going to be made of sheet metal you may face some distorsions since this feature doesn't take into account k-factor
6
Thank you so much for fast response. This is exactly what I needed.0
Is there another link to this somewhere? link says the document has been trashed and I've spent hours trying to flatten a cone =(0
6
