How do I get a large BOM not to go over the edges of a drawing?
I have this large BOM that I want to put in a drawing, however, when I put it into a drawing, it goes over the edges.
Is there a way to split a BOM to go over two sheets in a drawing or something?
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
See this discussion. This is something that will definitely be required in drawings.
https://forum.onshape.com/discussion/comment/29070#Comment_29070
I am sure this is logged in the Onshape system but I couldn't find a public improvement to vote on, I'll vote for this if you create it.5
Twitter: @onshapetricks & @babart1977
With the BOM, I ended up making the sheet A3 portrait so that the BOM would fit.
@brucebartlett
If the BOM is only just going over the edge of the drawing, you can usually fix it by decreasing the font size, but you get to a point where it doesn't make any difference.
Here's the improvement request:
https://forum.onshape.com/discussion/8599/split-bom#latest
IR for AS/NZS 1100
