regarding lag in movements
chand_basha
Member Posts: 66 EDU
hi,
when ever i try to rotate, pan or zoom it is taking too much time to show that action on the screen in a main assembly. could you please tell me why it is happening. and how to solve it
Try using "shaded without edges" view mode. that can increase your performance5
Rotate, pan, and zoom are typically tied to the performance of your local system (CPU and GPU). You can go to https://cad.onshape.com/check to run a local performance check. If the gauge is not in the green, then you could benefit from a better GPU. If you are in the green, then there could be a different underlying issue. In that case, you could try a different browser to see if the performance differs.0
ok sir,
Thank you.0
