regarding lag in movements
chand_basha
chand_basha Member Posts: 66 EDU
hi,
     when ever i try to rotate, pan or zoom it is taking too much time to show that action on the screen in a main assembly. could you please tell me why it is happening. and how to solve it
  • Evan
    Evan Onshape Employees Posts: 68 image
    Rotate, pan, and zoom are typically tied to the performance of your local system (CPU and GPU).  You can go to https://cad.onshape.com/check to run a local performance check.  If the gauge is not in the green, then you could benefit from a better GPU.  If you are in the green, then there could be a different underlying issue.  In that case, you could try a different browser to see if the performance differs.
  • chand_basha
    ok sir,
     Thank you.
