Move selected pieces between branches
brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
I just spent the last couple of hrs redoing a drawing which was completed and sent out to manufacture. I've now just got the end of the task and realized I did all this work on a test branch I was working on yesterday which has the TLA completely reconfigured to an older version of the product. I tried to merge but all I want is the updated drawing and not all the alternate changes I made to the old version assembly. Is this possible? I'd hate to have to redo all my work on the main branch.
  • lanalana Onshape Employees Posts: 761 image
    Try copy and paste of the drawing tab on the test branch into the Main and then sync the drawing. I just tested a simple case - it worked. Hope it works for you too.
    Thanks @lana
