dimensions
hobie_smith
hobie_smith Member Posts: 35 ✭✭
edited March 2018 in Community Support
Hello, is it possible to dimension a bending part in the 3d view and print out this area?
How do I measure 11.22 in the drawing?
Do I have to make a second sketch which I put over the bending part and transfer the line from the second sketch back to the first sketch? So I have a guide for the dimensioning?
Is not that easier?
  • john_mcclary
    are you trying to size the model using 11.221 as your input? or are you trying to show 11.221 on your paper drawing?
  • hobie_smith
    Thank you. It can be so easy if you know how ;)
  • john_mcclary
    For sure!
    Importing sketches in drawings that are paramtricaly linked to the model is still very new to Onshape.
    This is a just in time addition for you apparently :)
