Can I use embed 3D models on my website ?
florescu_cristian
Member Posts: 2 EDU
I just wonder if I can put my future 3D models on my website, using the Student account ? This it would be like a personal portofolio for future employers, or friends. I don't take any money, because I don't sell the models.
So, what do you thing ? I am allowed to do this ?
Not sure about the licensing agreement. Seems like you should be able to show your work without violating the terms.
On the technical side, you can show your models but it'll take a few steps:
-if you want them to spin, then you'll have to have a webgl viewer
-then export an stl file, convert to a display list, and add to your viewer
If you hook up to OS using the api, you can select which documents you want to show.
I'm not sure how much effort you want to put into this online portfolio, but it's totally doable.
Export the parts as stl file, then use an online STL viewer which can provide you embed code. Use that code to embed your 3D model.0
i thought that your workflow is yours and you don't need any permission to use at will, am i wrong?0
