Flat pattern from convert
bill_de_la_vega
Member Posts: 20 EDU
Having some trouble creating a sheet metal model for my part. I realize some features won't be possible so I excluded the faces of them.
Model is here:
https://cad.onshape.com/documents/a71bc4365dae58b5c767636e/w/d7917624a78333e84709a4ea/e/262b54fa3622521777020b6d
Model is here:
Can you make the doc public? Link is view only.
Senior Director, Technical Services, EMEA0 -
Should be public now.0
@bill_de_la_vega
Can you recreate the failing sheet metal model feature and commit it using the green check mark? It would be helpful to see which faces you're trying to include/exclude.Jake Rosenfeld - Modeling Team0 -
This model looks like better suited for Thicken option then Convert0
Ok, I just did that. I also labeled the features somewhat arbitrarily since I don't have the mechanism that this goes into yet.0
Thanks, I'll have to look at that thicken option more carefully.0
