Spline constraints
Edward_Goodwin
Member Posts: 25 PRO
I'm looking to constrain splines within a drawing. I can't work out how to constrain the direction/length of the spline handle... Any tips?
Also, it appears that there are no spline handles for points except for the start and end points. Is that really true? How do I manipulate the length/angle of a curve within the spline? Surely this can't be the case otherwise it seems to me that splines are severely limited in comparison to other cad packages.
Al thoughts and (I hope) solutions gratefully received!
Hi @Edward_12
In a sketch, you can constrain a spline handle using dimensions or constraints (between the endpoint of the spline and the endpoint of the handle).
There are no handles on spline points at this time (please raise an improvement request). Mathematically a spline with handles on inner points is actually two splines end to end, so you can do the same thing in Onshape, it's just not as quick.
Hope that helps.
Senior Director, Technical Services, EMEA13
Hi @Edward_12
Hope that helps.
Senior Director, Technical Services, EMEA13 -
Thanks Neil. This is a useful little animation you've added. It's frustrating that it's not possible to do this in one spline as I need to create something which is effectively a wavy pattern over a non-symmetrical surface (hence I can't actually pattern a spline/curve). It means I'll need to create hundreds of individual splines and connect them together whereas in SW I could have done it with 12 and then simply constrained the handles... Hey ho. I'll make the feature request.0
Good to know. Getting to using splines more in a model and this fits the bill. TY Neil.
