Move a part/sketch from one dokument to another.
Hey, I have imported a file from grapcad, but it is imported, as a dokument, how can i move it to the dokument im working on?
please help im stuck :pensive:
    edited May 2015 Answer ✓
    from the document you wish to import into click the + in the lower left corner then select import.
    You can also copy tabs between documents using RMB on tab and select 'Copy to clipboard' then go to another document and use the + sign on left bottom and select paste.
    //rami
    //rami
Howdy, Stranger!
