Part Renaming - can the format be changed?
daniel_cook
PRO
With the attached document, I'd like the part numbers to be more like:
"Flange-30-5-150" instead of the full "Flange-0.03 meter-0.005 meter-0.15meter".
I know nothing about Featurescript and not sure where to start looking. Can anyone point me in the right direction?
Can this be changed in Featurescript or do I need to change my in document variables?
https://cad.onshape.com/documents/9eba848c5290df456b40da6a/w/8d358666fe0c0c0025a6dddf/e/1e8bff6e3efa88f6bb38da01
Thanks!
Thanks!
In the renaming feature you can see variables of length type inserted into fields Segment1/2/3, to make those values unitless try to insert those variables divided by unit: Segment1 -> #Flange_Width/mm, Segment2 -> #Flange_Thickness/mm and so on
1
1 -
Brilliant!
Thanks worked like a charm.0
