Mirrored Sheet metal
Mathieu_Guilmette
Member Posts: 12 ✭
I mirrored my sheet model but I want it to create a new entity because
they are not cut in the same sheet metal. One is for the left side and
the other for the side so some bends are not the same. Is there a way
for the mirrored part to become its own sheet metal model?
You can not split sheet metal models currently. You can use sheet metal table to change bend radius of individual bends.
https://cad.onshape.com/documents/4a079f05c8c5469816224cb4/w/3f7cbdc5408b24c152dd7591/e/ba3591ffe3a02870234643f4
5
5 -
I really like how we see multiple parts in the flat pattern layout but it doesn't feel right that the table is all combined together in 1. I wonder if an improvement could be made to group bends per linked part in multiple tables in the table layout area.1
@brucebartlett
That sounds reasonable - please create the IR.0 -
@brucebartlett I was thinking the exact same thing because it creates it's own part when you mirrored it. So it would be nice that it creates it's own sheet metal model!!!
