repeat an action / feature (easy way to camfer holes in a pattern)
markymarky Member Posts: 2
edited May 2018 in General
Hello,
I've made a ring and with a circular pattern of cubes I made square holes in it. Not I neet those holes to be chamferd - as highlighted on the picture.
How do I chamfer all the holes without having to click all the 4 sides of all the holes?
I know that in Fusion360 you can repeat an action from the 'timeline'.
I've found something that could be the answer but I don't seem to get it working.
  • markymarky Member Posts: 2
    I figured it out! For anyone with the same question; here is how you probably should do this :)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,985 image
    Include the square hole and the chamfer in the same pattern feature (so there should only be 1 pattern feature).
