BOM properties
Mathieu_GuilmetteMathieu_Guilmette Member Posts: 12
Is there a way to change the “by default” BOM for every document in my OnShape? Instead of adding columns and reorganizing my BOM each time?
  • mthiesmeyermthiesmeyer Onshape Employees Posts: 115 image
    Hi Mathieu,
    Not at this time, but if this is functionality you would like to see please file an improvement request to the right ->.
    Thank you,
    Mike
  • Mathieu_GuilmetteMathieu_Guilmette Member Posts: 12
    Thanks!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
    @Mathieu_Guilmette another way is to create a default “template” document that has your BOM setup correctly. Then whenever you need a new document, copy your template rather than use the “create” button.
