this document is view only
walter
Member Posts: 41 EDU
how do i turn this off?
hi bradley found the problem , i'm on the free plan but have a education subscriber, found my son playing must have set to private on me thanks for the help
how do i turn this off? this document is view only0
@walter are you the owner of the document? If not then the person that gave you access may have restricted you permissions to view only. If you had private access to make/edit this in the past and are now under the free plan then this will also cause you to have view only access. You can still export whats in the document and perform operations like measuring.0
yes i'm the owner
