this document is view only
walter
walter Posts: 41 EDU
how do i turn this off?
  • walter
    hi bradley  found the problem , i'm on the free plan but have a education subscriber, found my  son playing must have set to private on me thanks for the help
  • walter
    how do i turn this off?  this document is view only
  • bradley_sauln
    bradley_sauln Posts: 373 image
    @walter are you the owner of the document? If not then the person that gave you access may have restricted you permissions to view only. If you had private access to make/edit this in the past and are now under the free plan then this will also cause you to have view only access. You can still export whats in the document and perform operations like measuring.
    Twitter: @bradleysauln
  • walter
    yes i'm the owner
  • walter
