How do you export a DWG file
I have some simple parts that I would like to export in DWG file for water jet cutting
 can anyone help with this?
This is one of the parts I would like to export for water jet cutting
https://cad.onshape.com/documents/32e6c6c472e23e862c411d62/w/303fc098cfc0fc22d9aa4763/e/80d66f6777ad112c15e7354f
  • john_mcclary
    You can add each part to a drawing. Then right click the drawing tab and export as dwg.
    If it is a sheetmetal part, you can open the simaltanious sheetmetal flyout, then right click the part and export.
    If you can use 3d parts to cut. Then you can right click the part and export to a 3d format. IMO it's easier to just export the 3d. Not sure what cam software your using is. But all the i have used support 3d
