Create multiple size rings stacked
paul_bartlett
Member Posts: 98 ✭✭
What would be the best way to create a stack of rings (each ring is 16 different parts) with each ring having a different diameter, different height and different depth. These would be stacked then turned on the lathe to make a vase. In inventor I would make a copy of the origional then change the parameters.
https://cad.onshape.com/documents/19ccedfa79bcaae737fc2b78/w/57ef42aa3da09539b7ab6acb/e/595ed0d6e4e6dca34a193ead this is the ring I am starting with.
If you want to get an idea of what some of my finished pieces look like go to www.paul-bartlett.com
@paul_bartlett
Short answer: Yes
How to do it:- Set up the whole thing in an assembly
- Create a new Part Studio in-context of the assembly (there is a tool in the toolbar, or you can right click on the origin of the assembly)
- Use the "Transform" feature to "Copy in place" all of the ghosted parts from the assembly
- Do the revolve cut on the copied parts
Jake Rosenfeld - Modeling Team7
I should add click on Gallery 1 at the top of my page0
@paul_bartlett I'd recommend creating a configuration for the Part Studio where you have 'diameter', 'depth', and 'height' configuration variables. Then in an assembly, as you insert each ring, you can fill in these configuration variables to adjust each stack as you go.
Wonderful gallery by the way!0 -
I will have to make a revolve cut after everything is stacked to get my inside and outside profiles. Will I be able to do this in an assembly?0
@paul_bartlett
Short answer: Yes
