Create multiple size rings stacked
paul_bartlettpaul_bartlett Member Posts: 98 ✭✭
What would be the best way to create a stack of rings (each ring is 16 different parts) with each ring  having a different diameter, different height and different depth. These would be stacked then turned on the lathe to make a vase. In inventor I would make a copy of the origional then change the parameters.
https://cad.onshape.com/documents/19ccedfa79bcaae737fc2b78/w/57ef42aa3da09539b7ab6acb/e/595ed0d6e4e6dca34a193ead     this is the ring I am starting with.
If you want to get an idea of what some of my finished pieces look like go to www.paul-bartlett.com
  • paul_bartlettpaul_bartlett Member Posts: 98 ✭✭
    I should add click on Gallery 1 at the top of my page
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    @paul_bartlett I'd recommend creating a configuration for the Part Studio where you have 'diameter', 'depth', and 'height' configuration variables. Then in an assembly, as you insert each ring, you can fill in these configuration variables to adjust each stack as you go.
    Wonderful gallery by the way!
    Twitter: @bradleysauln
    I will have to make a revolve cut after everything is stacked to get my inside and outside profiles. Will I be able to do this in an assembly?
