configuration not working or missing feature? [loft in configuration]
franco_otaola
Member Posts: 23 ✭
hello,
I wasnt sure in witch category place the question,
i was trying to use the configuration with loft and i couldnt select the profiles inside the loft feature, i can choose all the other parameters but not the profiles (it doesnt became yellow and cant click it)
but i am not sure if it is a bug from the configuration or if it is a missing improvement...
NeilCooke
Moderator, Onshape Employees Posts: 5,925
Loft (and some other features) use "array parameters" which allow you to select more than one item. Currently these are not supported with configurations. You can create or vote on an improvement request in the category on the right --->
There may be ways around it if you want to post an example?Senior Director, Technical Services, EMEA5 -
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi,How many config options do you have? Could you do separate lofts for each and then use the configuration to suppress the ones you don't want? This might create different internal ID's so might be a bit more to configure downstream to keep it all happy.Cheers,Owen S,Business Systems and Configuration Controller
HWM-Water Ltd5
HWM-Water Ltd
maybe i ddint explain myself correctly, i wanted to know if it was a missing feature ( as neil mention) to be able to suggest it.
thanks!
