Is there any plans to add GibbsCAM connector for Onshape?
Hi There,
We use GibbsCAM for CNC manufacturing and right now I have to export all the parts needs to be programmed as a Parasolid. I would like to avoid that if possible. So, just checking if a connector for GibbsCAM is on the cards?
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
You are best to chase up your GibbsCAM people as a connector will be coming from their side. If you can put pressure on them maybe they will create a connector for you.5 -
joe_dunne Onshape Employees, Developers, csevp Posts: 198
Bruce is correct. The best thing you can do is let Gibbs know you are interested in improving the workflow between our products. We would welcome it.
Joe Dunne
Developer Relations
jdunne@onshape.com
Joe Dunne / Onshape, Inc.5
Twitter: @onshapetricks & @babart1977
Joe Dunne
Developer Relations
jdunne@onshape.com
