How to create a cylindrical shape as a wedge
Hi, I am trying to make a round wedge.  Just a 76mm cylinder with a 12.3 degree slope on one of the flat sides.  I can’t figure it out.   Help us much appreciated.
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 979 EDU
    I think you could just make a 76mm cylinder then extrude a cut with a 12.3 degree slope.  I used the Use tool to grab the edges of the cylinder in my second sketch.
  • matt_rockliff
    matt_rockliff Member Posts: 4
    Hi, I ended up just making a rectangle wedge and it was suffice to my requirements.  Thanks for your answer 👍
