Can I simulate a Geneva drive?
devyn_snowhawk
Member Posts: 5 EDU
Like the title says I am trying to animate a geneva drive. How do I do this? Already modeled it but the gear relationships I see are continuous. I need an incremental gear relation with a degrees per rotation field or something
I've seen people fake it with something like this.
4 -
Woah. Can you elaborate?0
I'm using a Rack and pinion relation. The little gray follower part is the rack and the geneva wheel is the pinion. The vertical position of the follower is driven by a tangent mate and a sort of track. I animate the horizontal position of the track, which moves the follower, which rotates the wheel. The track could have just about any shape. I could also hide the track and follower and it would look like the wheel was undergoing incremental motion.1
@john_mcclary has done some work on what I call Animation Timelines... He did an amazing animation of solving a Rubiks Cube (https://forum.onshape.com/discussion/10484/rubiks-cube-mate-animation).
I've used some of his work/ideas in the subject in a couple of animations of my own....and If I could figure out how to post a video here I'd share it!
1 -
Thank you!0
@Matt_Shields can you please share the link?
I can't find my original, but here is where I got the idea.
