Simple taper, how to
angelo_bovaraangelo_bovara Member Posts: 5
I have this board I made.
The top face must stay as is.  That is to say it's the fixed plane in space.
The right face should measure 45mm x 20mm.
The left face should measure 68mm x 24mm.
The bottom face should taper from left face to right face.
How do I make it do this?
Additional information:
I was able to make the front and back sided taper from 68mm to 45mm based on the sketch. Since the top face is the reference plane, that's the one I drew on the sketch.  Then I extruded the sketch into the board you see here. I was hoping in the extrusion that I could constrain a plain and define the other plains based off of it. I am not able to do this.
