measuring distances for extrudes - beginner question.
rlbrk
rlbrk Member Posts: 31
Hi, in what way I can know how to set both of the extrudes that they will be flushed and be flat surface? it doesn't seems practical to go to each one of the extrudes and do the math yourself to make the lenthg of the extrudes match to a certain point. Cant you see the measures on the extrude tab? I'm sure there is a better way than do it manually...?
