Pullback / Inflate / Deflate a sketch or extrusion
mark_waller
mark_waller Member Posts: 4
I am making a sign for my classroom door. The idea is to print a base plate in one colour with indented cutouts to fit the text and the school logo which I will print in another colour. You can see the general idea here
https://cad.onshape.com/documents/f59adf9d461b7ce01f9efa04/w/271406c4968ac5415f4c748c/e/75b1a9890b7f4256fe6dc370?renderMode=0&uiState=66826e86ce781268af5a6530
To make sure the text/logo parts will fit inside the base plate I need to either shrink the parts slightly or grow the cutouts slightly. A simple transform won't do it, as that changes the size of the part and therefore the position of corners etc. it needs every edge to move perpendicular to the edge - i.e. I need to inflat or deflate the shape by 0.4mm in all directions.
Is there a way to do this in Onshape?
TIA - Mark.
