Improvements to Onshape - October 11th, 2024
Roy_Mutalik
Roy_Mutalik Member, Onshape Employees Posts: 41 image
edited November 2024 in New in Onshape
Our 14th release of the year comes full of improvements in a lot of different areas. Let's jump right in.
GENERAL IMPROVEMENTS
EXCLUDE HIDDEN PARTS ON EXPORT
You can now choose if hidden instances are included or excluded from an output file during export.
https://onshape.wistia.com/medias/f9zjdy345m
PART STUDIO IMPROVEMENTS
PARTIAL FILLET END CONDITIONS
Two new end conditions have been added to the fillet feature, allowing you to parametrically define partial length fillets. The Entity End type allows you to select a reference at which to terminate the fillet. The Offset End type allows you to define a distance from the end of the fillet edge at which to terminate the fillet.
https://onshape.wistia.com/medias/5cjvkh8tyv
ELEVATE DEGREE OF BEZIER SKETCH CURVE
You can now elevate the degree of a Bezier sketch entity. Elevating the degree maintains the identical sketch geometry, while adding additional control points.
https://onshape.wistia.com/medias/xhcohmb5ul
ASSEMBLY IMPROVEMENTS
MASS PROPERTY CALCULATION WITH ITEMS EXCLUDED FROM BOM
An icon and warning have been added to indicate if a total calculated mass of an assembly does not include any part or assembly instances that are excluded from the Bill of materials. This is true for computed values in the Bill of material's table, and the assembly properties dialog.
A calculated assembly mass viewed from the Mass and section properties dialog always includes all instances, regardless of their status in the BOM.
https://onshape.wistia.com/medias/87uuflpk2g
UNFIX PARTS FROM TOP-LEVEL INSTANCES
Right-click on any assembly or subassembly and select the new Unfix all command to unfix all fixed instances within the selected subassemblies, folders, parametric Part Studios, patterns, and replicates.
https://onshape.wistia.com/medias/z1ij1yewkk
DRAWINGS IMPROVEMENTS
DETAIL VIEW STYLES
New Detail view styles have been added. The default Detail view style can be set from the Drawing properties panel.
https://onshape.wistia.com/medias/xyo9ux1jod
PROJECTED BREAK VIEWS SYNC WITH PARENT
If a Parent view contains a break, any Projected views created from that view inherits the break.
https://onshape.wistia.com/medias/hsqg3m5yj7
ENTERPRISE IMPROVEMENTS
NOTIFICATION OF GLOBAL PERMISSIONS CHANGE (Temporarily disabled)
When a change is made to your company's Global permissions, all Administrators are notified of the change by email.
RENDER STUDIO IMPROVEMENTS
DELETE MULTIPLE INSTANCES
You can now multi-select and delete multiple instances at once in a Render Studio via the Scene list context menu. Note that you cannot delete faces or parts underneath a Part Studio/Assembly.
MERGE CHANGES
You can now Merge changes in a Render Studio. This allows you to leverage Onshape's powerful parallel design workflows through design branches, even when working on a rendering of your product.
SELECT MULTIPLE APPEARANCES
Selecting multiple appearances at once, you can now navigate between your selections from the Appearance panel. Each appearance will independently cross-highlight the geometry it is applied to.
INDICATION OF MANUAL TESSELLATION OVERRIDE
Any instances using a tessellation setting other than "Auto" displays a diamond icon in the Instance list. Hovering over the icon provides a tooltip showing the selected tessellation level.
LEARNING CENTER IMPROVEMENTS
CERTIFICATION IMPROVEMENTS
The Certified Onshape Associate and Professional exams have been moved to a new platform that is embedded directly in the Learning Center. We hope this provides a more streamlined experience.
The Associate exam has been completely overhauled, including new modeling challenges and multiple choice questions.
INTRODUCTION TO THE ONSHAPE API COURSE
We are excited to release a new Introduction to the Onshape API course in the Learning Center. Learn the fundamentals of the Onshape API using the Onshape Glassworks API Explorer, which allows you to make API calls with zero code.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.
  • shawn_crocker
    shawn_crocker Member, OS Professional Posts: 1,040 PRO
    Render studio looks like it is starting to pick up development momentum now. Very glad to be able to have a detail view linked with a leader.
  • romeograham
    romeograham Member, csevp Posts: 777 PRO
    The Hiding parts from export is interesting.
    The old default behaviour was to exclude hidden parts on export. This causes some problems because it could be tied to the hide/show state when an assembly was versioned or released. I ran into this when I Released an Assembly with a part hidden. The hidden part was released just fine, but was thereafter NOT able to be exported - even if it was visible in the released assembly!
    This new button seems to indicate that the default has changed (meaning - by default it will export everything in the assembly, regardless of visibility state), and you can select the button to force the old default behaviour.
    Nice to see the control either way!
  • rick_randall
    rick_randall Member Posts: 436 ✭✭✭
    I like the unfix option, it will help me go back and clean up some old models. Also the drawing improvements will be handy.
  • Lewis_Maina
    Lewis_Maina Member Posts: 12 ✭✭
    Theses new features are compelling, unfixing all parts in high-level assembly is great time saver.
  • antero_nick
    antero_nick Member, csevp Posts: 18 PRO
    Appreciate the work that went into making an improvement to the mass property management of assemblies in this update.
    Curious if the feature request that I had submitted in 2020 is still on anyone's radar. Long story short: when there are multiple instances of the same part within an assembly their masses may all be the same, but their locations in space are different. Allowing for a BOM view that allows these per-instance unique attributes to be seen will help the mass property management workflow for large teams working in big assemblies - like aerospace vehicles.
  • ken_xu
    ken_xu Member Posts: 14 PRO
    “EXCLUDE HIDDEN PARTS ON EXPORT” been expecting this for a long time, great to see it.
  • robert_johnston
    robert_johnston Member Posts: 83 PRO
    Thanks for this Update, good work Onshape.
    In the changelog
    "Fixed display of attempted failed geometry with when using sheet metal extrude on a closed profile"
    This is a huge fix for me! Wonder if other sheet metal workers notice 😁
  • Chris_D_Mentes_001
    Chris_D_Mentes_001 Member, csevp Posts: 129 PRO
    Detail View Style! Yet another checkmark off my bucket list! Now my drawings can look more like my colleagues.
    Weirdly I never use splines for work but the bezier controll point adjuster still excites me.
    And very VERY excited to see the API course is finally here!
  • Hans_Leirvik_1
    Hans_Leirvik_1 Member Posts: 40 ✭✭
     BREAK VIEWS SYNC
    Finally !! Missed it for some time, long time … Thank you :) Very good!
  • JosefBurjeta
    JosefBurjeta Member Posts: 30 PRO
    @S1mon +1 on the "Decrease and try to maintain the shape" improvement. Unless you go to the Degree 1, there's no excuse to create a straight line.
    I already created a ticket to Detail view profile line. It's really nice to hide it completely, unfortunately you still need keep the one, which intersects 3D geometry to better understand what you're looking at. I would most likely create such line in phantom style, with option to use dashed or solid line. It's also important this line is thinner than 3D geometry so you can easily distinguish between detail boundary and 3D geometry.
    Definitely need to got through API course, that sounds really interesting, thank you for that.
    Partial Fillet with new options looks very promising, I need to test that but I believe it will be a great improvement for various design tasks.
    Unfortunately, help URL in Enterprise is still general Help site for Structure view. Please check.
    • Fixed a specific help URL for Product structure view to link to proper documentation page
  • ole_bachmayer
    ole_bachmayer Member Posts: 3 ✭✭
    This actually sounds like a great opportunity!, maybe you can manage to add the dergree-Handler (optional) to lines, so you can change a line to a spline and vice versa
    S1mon Member Posts: 4,513 PRO
    Very good points. I've added this to the improvement request thread. Other CAD tools definitely enable switching a line to spline and vice versa. Under the hood, lines are just degree one splines. Currently if you try to delete the middle control point from a degree two spline, you get this mathematically incorrect error message:
  • Nath_McC
    Nath_McC Member Posts: 136 PRO
    I am very happy to see PRtOJECTED BREAK VIEWS SYNC WITH PARENT.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,945 PRO
    edited October 2024
    API course, much appreciated!
    Nice to see those drawing and render improvements too.
    Oh and spline improvements?!
    RENDERCAD
  • MichaelPascoe
    edited October 2024
    That was a great API introduction. Really good content. Hope we will see more content for learning how to use the API:
    • Authentication / app template example
      (Most users will not know how to do this, if they are already a dev, then they wouldn't need the course to begin with 😉)
    • C# Examples
    RENDERCAD
    On a more positive note, adjusting the degree of a Bézier in sketcher is much better than Solidworks in terms of how it handles constraints. From what I remember, you need to remove almost all constraints from a curve in Solidworks in order to change the degree. Onshape will make a better attempt to honor constraints, including tangent, curvature, and through points. Until the free state degree reduction is improved, it looks like you can throw some through point constraints onto the curve, and tie down some tangency/curvature and perhaps get to where you want to be.
  • reinhard_weber
    reinhard_weber Member Posts: 3 ✭✭
    Very good improvements.
    I like Onshape.
  • SledDriver
    SledDriver Member Posts: 117 ✭✭✭
    edited October 2024
  • glen_dewsbury
    glen_dewsbury Member Posts: 1,374 PRO
    On the spline when it's created.
  • larry_moore607
    larry_moore607 Member Posts: 2 ✭
    How can I turn off the background when sketching? I can't even evaluate this. I can't see the sketch I imported.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,878 PRO
    Oh no!
    Is it going to be a sad week-end?
    @eric_pesty It's looking that way. Every now and then there's a really late in the day release, but I'm guessing we're looking at Monday.
    Nevermind. Just hit refresh and there's some amazing things…
