Printing help
peter_hall
Member Posts: 196 ✭✭✭
Getting this top and bottom data lines. Is there a way of getting rid of these, quite annoying an only started with the new onshape helpful area for print!
Evan
Onshape Employees Posts: 68
Hi Peter,
When you say data lines, do you mean the page name, url, etc...?
I know Firefox will add those to its prints, by default. They can be removed by going into the page setup:
Once, you have the page setup dialog open, you can go to the "Margin & Header/Footer" tab to remove all the header/footer items:
For best results, I also recommend setting the margins to 0.
How you get to the page setup can differ depending on your operating system. The screenshots I took were from Windows 10.
I have not seen the border being added. If you find that this is making it into the final print, please log Feedback through the help question mark-->Feedback, and we will look into the bug.
7
