Struggling with text orientation
len_2
Member Posts: 8 ✭
I'm trying to put extruded text on opposite sides of a simple object. Let's for, example, say the text is "FRONT" and "BACK". I can place the "FRONT" text OK, but when I place the "BACK" text on the opposite side on the object the text is backwards, and often upside down as well (but oddly not always upside down). I can't figure out how to get it so it reads in proper direction.
Here is an example. If you flip the disk around a vertical axis to see the back, you'll see the problem.
https://cad.onshape.com/documents/b3bf08d5d93943d097ce00b9/w/e1d8040a9f8644f1821537d8/e/3e1d2f6c324d484cb325c840
@len_2 ,
Your example displays properly for me? Neither backward or upside down (when rotated vertically, I suppose it's upside down if spun sideways around a vertical axis).
What happens if you write the text on the 'front' plane and mirror it then remove the original? Would that work?0 -
Getting a lot of "Text" Questions.
It's actually easier than you think.
https://cad.onshape.com/documents/646253eead84426a84770e46/w/d193549e6568450c8d906be3/e/f957f390632f4f31bee53d6e
Philip Thomas - Onshape-1 -
Here is an example of text on an arc AND text on a curve
https://cad.onshape.com/documents/8ba6a3a478b145f2ab7b9f7b/w/93e3539053f744a1b3e6c50e/e/3ead7bc09f184ffa845e8931
Philip Thomas - Onshape0 -
@philip_thomas
Verreee crafteeee... and somewhat cryptic.0 -
@philip_thomas
The reversed text is a bit more of a fiddle in the case where there is not a parallel face on the opposite side of the part on which to conveniently sketch the desired text, no?0 -
If there were no parallel face, I would offset a plane and if after two tries i couldn't get it to work, i would thicken the back face as a new part and use the new parallel face to do the same thing.andrew_troup said:@philip_thomas
The reversed text is a bit more of a fiddle in the case where there is not a parallel face on the opposite side of the part on which to conveniently sketch the desired text, no?Philip Thomas - Onshape0 -
@/philip_thomas
I knew you'd say that ! (it is, indeed, a "bit more of a fiddle")
It would be scraping the bottom of the barrel, I feel, to resort to such inelegant kludges as creating a 180 degree (reversed plane) by stacking up two 90 degree intermediate steps...
I look forward to the day when we have a "Flip Plane" command in Onshape.
I'm not aware that even SW has got around to that as yet. I'm not averse to a bit of flip flopping!0 -
Hi Len one possible approach is to remove the horizontal constraint from the box that contains the text and simply rotate it to your desired position, see video below.len_2 said:I'm trying to put extruded text on opposite sides of a simple object. Let's for, example, say the text is "FRONT" and "BACK". I can place the "FRONT" text OK, but when I place the "BACK" text on the opposite side on the object the text is backwards, and often upside down as well (but oddly not always upside down). I can't figure out how to get it so it reads in proper direction.
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions0 -
nav said:Hi Len one possible approach is to remove the horizontal constraint from the box that contains the text and simply rotate it to your desired position, see video below.
I still don't get this and it doesn't work for me. This is _not_ about rotation, it's about text direction. I don't get "Back" upside down on the back-side of my part, I get it in reverse order, i.e. kcab with each letter flipped horizontally. I need a FLIP not a rotation.
What am I missing?
It's a nice example although you are on the _sides_ of the object, not the front or the back. Also, can you explain how to do this instead of showing the finished product?philip_thomas said:Getting a lot of "Text" Questions.
https://cad.onshape.com/documents/646253eead84426a84770e46/w/d193549e6568450c8d906be3/e/f957f390632f4f31bee53d6e:smile:
Thanks.0 -
@gray_watson
@philip_thomas
It is a bit tangential to your conversation, but I have just finished a FeatureScript that makes it easy to add text along a curved surface, adjust spacing, etc:
You can adjust the text orientation, but also the height, spacing, and the curve along which the text rides:
You can read more here:or simply load up the document directly, here:
Enjoy, and of course I'd love feedback if you've got it!
1 -
philip_thomas said:Here is an example of text on an arc AND text on a curve
how the hell do we do this!!!?!!??!!?!?!?!?!?!0
Here's the trick that works for me: otate the box, remove the horizontal constraint on the lower edge, apply a Fix constraint to one corner, then drag an opposite corner." Ref: https://cad.onshape.com/help/Content/text-rectangle.htm0
